FIXED DV56H9100EG/A2 Samsung Dryer - Te error code.
Shaman
U.S
Rick,
Thank you so much that fixed that code!
One more question, now that it's running if I put it on timed dry it runs thru the whole cycle when I place it on any of the cycles that detect moisture it runs for 3 mins and then starts cooling would that be a bad moisture sensor?
That's correct. If you don't have any wet clothes in the dryer it thinks the load is done and shuts off. I guess you found the broken wire?
Shaman
U.S
I did, the blue wire at the thermistor connector was the culprit, when I went to examine it, it pretty much just broke right off.
