DVL223EB1W GE Dryer not heating after move
jkelly2014
Garland,TX 75043
DVL223EB1W
I have a GE electrical dryer and it is not getting hot after my move. What do I need to start with? serial is AD743559W.
The first thing I always do is use my multimeter to do a volt test at the dryer terminal block, where the power cord connects to it.
First make sure your getting 230-240 volts at the terminal block in the back of your dryer. The outer wires are hot, middle wire is neutral. So put your volt meter probes on each of the two outer wires at the terminal block and see what your meter reads, you should get 230-240 volts between the two outer wires on the terminal block.
Yes it should. Can you pick one up locally at a hardware store near you?
Fantastic, let us know what you find!
