DVM1950ER2ES GE microwave no power unless power saver button is pressed
Docanderson
DVM1950ER2ES
Ok. I'm at a loss. Microwave suddenly has no power unless I push the power saver button in. It will work then, but the fan runs non stop. I get a message that it is on due to high heat and will shut off automatically, but it never shuts off, unless I push power saver again which cuts off all power. I have checked all fuses and tried replacing the main board, but this had no effect. Help?
Seap1970
Las Vegas, Nevada
We get that in Las Vegas during Summer. Customer complains, " I was in bed last night and all of a sudden the fan went on without me touching or cooking anything"
As Jake said possibly the control board or the Cavity Thermal Cutoff TCO
