ecoboost_xsport
- DW7933LRABB/A
- Samsung
- 6-10 years
Recently started getting this error. Washer starts as normal, then after some time it beeps and flashes this error. All the research I've done points to a drain error. I've confirmed this as nothing comes out the drain tube.
Some of the steps I've done:
- Cycled the power by unplugging for a while.
- Checked all hoses and ensured all were clear of debris or blockages
- Took apart the internal parts and cleaned everything down to the drain port.
- The rubber flap "check valve" was distorted so I bought a new one and replaced it.
- Purchased a new drain pump (Samsung product) and installed it.
- Removed the level/temp sensor (connected to the bottom of the brake case) and cleaned it out
None of these steps are working. Am I correct that this is a drain issue? I have seen some stuff of the internet saying the Quick" flashing could be a thermistor issue. I have not changed it, but the manual for my product even says that a flashing "Quick+" is a drain error.
When I run the unit, it seems that it fails when it gets to the part where it's supposed to start draining, but not sure. It's about 6 or 7 minutes into a "Quick" cycle when I test run it.
We've had the unit for about 7 years now.
Thanks in advance.
Thanks in advance.
