DW80F600UTS Samsung Dishwasher - Just replaced water inlet valve and now it won't turn on
Bens
Ohio
DW80F600UTS
Samsung
Dishwasher started leaking at the water inlet valve so I pulled it out, replaced the valve (swore a lot) and put it back together. Now the stupid thing won't even turn on!
A couple things: I was able to replace the valve without flipping the unit. I also tested power everywhere I could. Breaker is good, power at the inlet is good. Board has power too (tested from main black wire). I also pulled the control panel to see if a wire was loose and no dice there either. I checked all the plugs on the main board and nothing seems loose. Also tried pulling power for a bit to see if it gets better and nothing.
I'm out of ideas.
Here's the service manual: https://drive.google.com/file/d/1b4U7QUGtsBxRqWn5wJuIcx_c48EbKHDc/view?usp=sharing
On Page 56 do the AC Voltage TEST and the DC Voltage TEST it says to do there for the No Power Problem.
Here's the screen shoot of it:
