- DW80F800UWS
- Samsung
- 6-10 years
my Samsung DW80F800UWS is overfilling.
shows error code oE (which the Samsung manual unhelpfully describes as: Over-level water error Functional error. Close the water supply valve and go to your house circuit breaker panel, set the dishwasher’s circuit breaker switch to off, and then contact an authorized Samsung service center.)
the unit is draining well. forcefully. almost constantly.
when I open the door at any point I can see water flowing in the cavity.
to recap.
cycle starts normally.
after about 2 minutes it drains. and then keeps draining . and keeps filling.
even when the power is cut from the unit, water keeps flowing in, as long as the inlet line is Open.
so what am I looking at here? bad water inlet valve?
its a jazzy unit. (and for once the control panel seems to be working correctly)
this seems like it should be a fairly simple diagnosis and.... hopefully.... fix
gratefuly as always for your help.
Peter
to recap.
Peter
