DW80K7050US Samsung Dishwasher Error Code 3C
Mr Kyle
Saskatchewan
DW80K7050US
Samsung
When trying to run a cycle, the dishwasher hangs, won't complete the cycle, error code 3C displays and water is present in the bottom. When you press cancel it promptly pumps out the water, so I know the pump works.
The user manual says "Pump operation check - Functional check. Turn off the dishwasher and try to start it again. If the problem continues, contact an authorized Samsung service center."
I've re-cycled power several times but no success.
See attached for user manual.
I have a multimeter and can do electrical troubleshooting, just need to be pointed in the right direction. Any help much appreciated.
Thanks.
  • DW7000KM-02025B-01_EN_CFR.pdf
Error Code 3C:
(click to enlarge)
You can see the first thing it says is to check for something stuck in the circulation pump. You will need to remove the circulation pump and check for something stuck in it. Its a big job to do, is this something you think you can handle?
Here's the circulation pump for your model:
