FIXED DW80M2020US/AA Samsung dishwasher blinking normal trying to drain
Davisge2
Michigan
DW80M2020US
Samsung
Samsung dishwasher:
model number DW80M2020US
normal light blinks drain is on and when I try to power off it turns it self back on and keeps doing the same thing.
Davisge2
Michigan
Book says water leakage,
leakage switch is broken
Leakage switch activated for 2 seconds
problem with the main pba
Davisge2
Michigan
After opening the panel below saw some water was inside don’t know where it came from. Wiped off all the water and plugged it back in and it worked again. Waiting to see if it happens again and to find out where the water is coming from.
Which panel? The very bottom access panel below the tub?
Davisge2
Michigan
Yes bottom panel below the dishwasher. There was a sensor on the floor and looks like that might be what was setting off the water leakage alert. there was water in there when i opened it up. I still dont know the source but did run two loads last night without any issues and no issues today...
Yes, that is odd, just keep an eye on it and see if that water comes back.
kroon78
Lower Sackville, Nova Scotia
For what it is worth, i pulled mine out, tilted it back, and some water came out of somewhere. Cleaned that up off the floor and turned the breaker back on at the panel, and voila, the alarm went away. Its running right now!
