- SGE63E05UC
- Bosch
- 1-5 years
model is the bosch SGE63E05UC dishwasher
its displaying the e24 drain error. i have replaced the drain pump, the new one is much quieter. Note, i have checked for clogs, there are none.
the problem and work around is as follows:
after pressing the start button the drain pump will run a few seconds, then the circulation pump will run a few seconds, and finally the drain pump will run for a minute after which there is the e24 error
however, if during the minute the drain pump is operating, i just quickly open and close the door, the drain pump will stop and the program will progress to the wash cycle (wash cycle light comes on). the dishwasher will function normally.
my best guess is the circuit board or sensor is faulty.
how does the computer determine that there is a drain problem? the drain pump is able to remove all but maybe an inch of water from the sump where the drain pump impeller is. why would just opening and closing the door progress the program to the wash cycle?
