I guess my post was not really clear. This fridge is an 03 model never had water hooked up. I hooked up water and turned the valve on. Those two lines pictured are cut. No idea where they went. Trying to find a diagram. Water does not come from the water dispenser when pushed. It pours from one of those tubes.
Edit:
Looks like they are the supply and return for the water dispenser since the ice maker is a straight run up the back.
No clue why they are cut.
Are they supposed to loop inside the fridge to cool the water then come back down under the unit and then up the door?
Ok bypass all that and just go right into the door?
