FIXED EFLS617STT0 Electrolux Washer E59 Error
ALN
Beaufort, SC
EFLS617STT0
Electrolux
Problem: Electrolux Washer EFLS617STT, purchased it in 2018 new. Indicates it has an E59, removed the back panel and noticed that the plastic pins where not connected to the back shock absorbers. So, I placed the pins back. Still had the same error code. Then I replaced the Machine Motor Control Board and cleaned out the coin filter. Agitates and spins fine when NO clothes are in the washer, everything checks out. When NO clothes are in the washer, it can go thru all the cycles and acts like a regular washer. But.....
Once, I put a small basket of clothes, and the clothes get wet, then the washer does not agitate or spin. It just stops. I can hear clicking sounds when clothes are in the wash but can't figure it out.
Any suggestions? I am at a lost.
Hi, I'm attaching your tech. data sheet below.
E59--->No spin signal for 3 seconds--->Refer to test (9)
Do what it says in TEST 9 and let us know what you find, you will need a multimeter to ohm test with.
Here's the motor for your model, in case yours ohm tests bad:
  • A05243601B.pdf
ALN
Beaufort, SC
Did the Ohms testing, and it still read zero. Used a secondary multimeter, same result.
Ordered the motor, while removing the old motor and unclipping the wires, noticed that it has a broken wire. Butt spliced the wire. This was found bound inside the electrical tape attached to the zip tie anchor. Ran a cycle with clothes, and it actually spun without stopping. Now, to return the motor that I never used.
Excellent, good find.(y)
