EI30MH55GWA Looks & Sounds like it's working = no heat?
ssacrf
Southeast USA
EI30MH55GWA
Electrolux
I've had this OTR microwave for 2 years. Worked fine last night and this morning, but tonight I get no heat.
It looks and sounds like it's working...lights come on, timer works, fan blowing, etc, but won't budge the temp on a glass of H2O after 3 minutes.
I just don't know where to start. :confused:
Edit: Model number is EI30MH55GWA (changed 1 to I)
EI30MH55GWA
An Electrolux with an inverter board = :eek:
1) Check your warranty
2) Take it in to local Frigidaire depot to be checked ( cheaper than someone comming to the house )
ssacrf
Southeast USA
I don't like the looks of that ^ :(
Jeff thanks for the reply. I checked the warranty and I'm outside of it (1 year warranty -- I've had it 1 year and 10 months :mad:).
Does being out of warranty change your recommendations, or does having an inverter board make this thing outside the "fix it yourself" type of problem?
thanks again!
-Steve
Taking the unit in for checking is still cheaper.
Inverters are a nightmare in mcirowaves, without proper testing equipment and manuals this could be way outside a DIY job :(
ssacrf
Southeast USA
Hi Jeff, thanks again for your advice on this.
I took the unit to a certified repair shop and the diagnosis is a bad Magnetron. They have quoted a price of $335 to complete the repair. I've noticed I can get the part for just about $100, so price wise, I'm better off buying the part and replacing it myself.
My question has to do with the fact that this model has a dreaded "inverter board"...is replacing the magnetron complicated by having an inverter board, or is it pretty straight forward? :D
Thanks again for your help!
-Steve
Same as any microwave...power off, capacitor discharged, remove a billon panals and such to get at the magnetron. This is not an over complicated job just long and tedious (sp).
Magnetron - EI30MH55GWA
