EIFLS60JIW0 Error Code E21 on Electrolux front load washer, Drains slow sometimes other times fast
Ghale330
Ohio
EIFLS60JIW0
Electrolux
Ok so this blog helped a lot especially with the coin trap part. I’ve replaced the pump twice brand new oem , the main board (used) , cleaned the coin trap , checked voltage during cycle and checked the gray drain and recirculation hose and pump. Have not replaced pressure sensor. Please help!!
Ghale330
Ohio
Seems like it drains slow sometimes fast other times but after that is usually when it just stops doing anything. I can pause the cycle then restart and will finish the cycle with or without actually running water in during the rinse and spin, that’s why I’m having a hard time diagnosing this thing.
Thanks, Your model uses this tech data sheet: https://www.dropbox.com/s/j29qczouwhz6dwy/EIFLS60LT0.pdf?dl=0
E21=Water not pumping out fast enough--->Refer to TEST 3.
E32=Pressure sensor calibration problem--->Refer to TEST 4.
E91=Communication error between UI board and main control board--->Refer to TEST 11.
It should be draining fast at all times. Have you checked all your hoses for partial clogs?
Ghale330
Ohio
Yes I’ve checked the coin trap and black tub to pump boot again . It doesn’t throw a code every time it gets “stuck” either. The last two were pressure sensor codes so I took the top off and tapped on the sensor, pushed pause then start, it then finished the cycle with no problem.
Also, remove the pressure switch hose from the pressure switch and blow hard into the pressure switch hose which goes into the air dome assembly, I've tiny pieces of lint get clogged in the air dome assembly and cause this issue too, make sure no water is in the tub when you blow through your pressure switch hose, that's very important!
Ghale330
Ohio
Ok no problem with the pressure switch hose. I replaced the pressure switch , board and another brand new oem pump. When it gets to a point when it’s supposed to drain you can hear the pump humm and I get a trickle of water most of the time but other times it’s the full flow the size of the drain hose like it’s supposed to be. Have you ever encountered an issue with voltage or wiring?
When you hear the drain pump hum, its not running?
Yes, rodents like to chew the wires this time of year and that will cause low or no voltage to the drain pump, check your wires to the drain pump thoroughly.
59Ranchero
Tulsa
My wife's electrolux was doing the same thing, intermittently, took it apart, slight stuff in the white basket, cleaned out, blew out the drain hose, hooked it up same thing intermittently. Took back apart and replaced the drain pump. Seemed to work fine for a couple of days and back again, not draining, E21 code. Pull the drain hose out of the wall as much as you can. If it's too deep in the wall, it creates backpressure on the draining and it triggers an error code. That fixed our problem as I had about 12 inches of drain hose shoved down into the wall.
