FIXED EIFLS60LT1 Electrolux Front load screen reads wrong
tseibring
Sheldon, Illinois, United States
EIFLS60LT1
Electrolux
After you turn the machine on, the screen reads the wrong times for each cycle. I tried resetting it after watching a video on line, but no luck. Wife said it isn't draning also.
I'm not sure I'm understanding, can you go into more detail please.
Also if you can take some photos or a video of what the time problem is that would help us too.
For the not draining problem, Check the drain hose for restrictions.
Check for 120 Volts AC at the drain pump WHEN it should be draining.
If 120 Volts AC Remove the pump and check for blockage. If blocked, remove the restriction, if not, replace the pump.
Here's the drain pump for your model(Video Included):
137240800 Pump-Water
Excellent tseibring, glad to hear the new pump fixed it.:)
