teoteodore
- JD630SFSS
THIS IS A TWO-PART QUESTION. In an earlier post, I mentioned replacing a 30+ year old GE drop-in with this new range. The existing electrical breaker has no identification, nor does the electrical cable. It is 220V of that I'm sure. The plate on the old range shows a maximum draw of 11.1 KW, which would 'suggest' about a 50-AMP protection. Since the new range requires 40-amps, I am going to assume the wiring is adequate, even if I change the breaker. Am I making sense?
The installation manual gives instructions for a hard-wire connection, yet both Sears and USAppliance websites tried to sell me a 3-prong plug (not included). I am going to assume the installation manual is correct and it'll be hard-wired. Here's the 2nd question: The existing Junction Box in the cabinet that connects the house power supply to the appliance BX cable is obscured by other cabinetry. Can I disconnect the existing appliance BX from the old range and run it to a new JB at the suitable height and location for the new range? or run it directly to the new range?
I tend to plan ahead (I don't have the new range yet).
