Electrolux Dryer EDH3386PJW error EH0
donpivo
Norway
EDH3386PJW
Electrolux
Hi! Hope you can help me with an Electrolux EDH3386PJW tumble dryer which presents error code EH0 when I try to start it. This error is allegedly caused by problems with the power source. The mains power is perfectly fine, so I'm guessing there must be a problem on the main board. There are no visual signs of damage to any components on the PCB. I tried replacing the LNK586GG IC, since this is a common problem cause, and tested all electrolytic capacitors and most other thru-hole components. I also tried bypassing the noise filter at the AC inlet.
Does anyone have a service manual for this dryer, or experiences with this particular problem?
We have no tech. data information on European Appliances, try UK Whitegoods.
