Electrolux EFLS517SIW0 - Not draining..
Nathan.Lang
Montreal
EFLS517SIW0
Electrolux
So I read this thread - HERE, ran the diagnostic got an error code 21 but also 23. I took out the drainage hose, pump and large black hose with the white trap connected to the tub. I cleaned them all and although some summy bits came out there were no significant blockages. I tested to see if the pump was working, which it was. Stumped I put the washer back together and ran the diagnostic again and got the all clear. I tested it with a spin rinse cycle that ran with no issue and the water drained quickly. I put a load of towels ( which i used to clean up all the water spilled from draining..) on a heavy duty cycle and it stopped at 22 mins to go water still in the tub.
I see that a lot of people have replaced the control board but it seldom seems to solve the problem.. I'm wondering if this sounds like a different problem? pressure switch? door lock? and how i might test for these.
Nathan.Lang
Montreal
Update: after taking out the towels I ran a sipn/rinse cycle and it drained quick and span up to 130 rpm. Tried again with a load of shirts, same thing stopped at 20 mins.. tried the spin/ rinse again without taking the shirts out and it stopped at 8 mins.
Error Code 21=Water not pumping out fast enough.
Error Code 23=Drain triac error
Both say to refer to TEST 3.
TEST 3:
1. Check the drain hose for restrictions.
If there is a restriction, correct the problem.
No restriction, go to step (2).
2. Start the washer and check for 120 Volts AC at the drain pump.
If reading zero, check the wiring. If wiring good, replace the main control board.
If reading 120 VAC, remove the pump and check for blockage. If blocked, remove the restriction, if not, replace the pump.
When it drains how fast is the water coming out the drain hose? Pull the drain hose up and watch how fast the water comes out, it should come out with a very strong flow out.
59Ranchero
Tulsa
My wife's electrolux was doing the same thing, intermittently, took it apart, slight stuff in the white basket, cleaned out, blew out the drain hose, hooked it up same thing intermittently. Took back apart and replaced the drain pump. Seemed to work fine for a couple of days and back again, not draining, E21 code. Pull the drain hose out of the wall as much as you can. If it's too deep in the wall, it creates backpressure on the draining and it triggers an error code. That fixed our problem as I had about 12 inches of drain hose shoved down into the wall.
