- EW23BC71IS7
- Electrolux
- More than 10 years
12 year old Electrolux French door refrigerator freezer temperature rising throughout day from 0 degrees F to roughly 12-13 degrees F on average usage then going back down to 0 after roughly 4 hours or so if don't open/use refrigerator/freezer. Noticed past 3 days freezer temp would be at 0 in morning and then noticed it going up as used during day and then back down if not used as well. The refrigerator section is maintaining consistent 37 degree F temperature so only freezer a concern at this point. Cleaned coils and refrigerator/freezer insulation/closing seems to be fine.
Ran system diagnostic tests after refrigerator got back to 0 Freezer and 37 Refrigerator temps as not opened for 4 hours and saw no errors from what I can see with following test results:
Test 2 Defrost Heater Test produced a slight noise when activated and when deactivated but not certain if actually heated up or not
Test 15 Evaporator fan motor test successfully ran at lo / hi speeds
Test 26 Defrost limit switch test came back as "Open"
Test 38 (VCC compressor test but don't really hear much other than a little click type noise at first).
Test 29 refrigerator thermistor test came back Good and showed 37F on left of display which is what refrigerator temp is set at.
Test 30 freezer thermistor test came back Good as well but showed 10F on left of display while freezer temperature is set at 0.
Not sure what other tests may provide insight or thoughts in general on above info. Thanks in advance for any assistance.
deeMatrix
deeMatrix
