nethalan
- E32AF75JPS1
- Electrolux
- 6-10 years
So 11 pm Friday night, my freezer unit started alarming Hi temp and the temp reading was 29. I checked to make sure nothing was blocking any vents and canceled the alarm to stop the beeping. I also noticed that water was leaking from the corners of the freezer door. I rechecked an hour later and temp had dropped to 27. Another hour passed and temp down to 25 and figured that the problem had passed or was on its way to resolving. At 6 am the next morning, the temp read 22 and 845 am reading said 0 and I thought back to normal. However, at 10 am the hi temp alarm for 29 degrees went off again and checking contents of the freezer, things like ice cream were already starting to melt. I looked online for troubleshooting tips and decided to empty my freezer and plan to open the evaporator cover to check the coils. When I did this I saw frost on the coils on the top third portion. Defrosted the freezer and checked to make sure there wasn't any blockage in the drain pan. I turned power back on the unit at noon and by 2 pm temp had dropped from 61 to 39 in two hours. I left the evaporator cover off so I could view the coils and fan. Checked the temp display throughout the day and noticed that leaving the door open for 10-15 seconds each time, the temp on the display would rise 2-4 degrees. By 11 pm the temp display did not drop below 39. During this 12 hour period, observations I made:
-the compressor feels hot to touch (i feel that the compressor is working it is hard to tell if the vibration I feel is from my full size upright fridge that is adjacent to the freezer)
-the condensor fan (at bottom of unit) seems to work as it is turning on and off intermittently during this period
-the condensor coils (at bottom of unit) feel room temp to touch
-I don't observe any cold frosty air in the freezer when I open the door
-the evaporator fan (inside freezer back panel above the evaporator coils) seems to be running continuously...by this I mean when I open the freezer door the fan is already running and the lights turn on. With the door open, when I push the door switch in, the lights go off as expected but the fan remains on. When I release the door switch, the lights go back on and the evaporator fan slows down momentarily and resumes previous speed.
Door gaskets all seemed fine but decided to re-lubricate just in case and check on the unit in the morning. This morning at 8 am the display read 38 and since the compressor still felt hot and no change from previous observations, I decided I would shut off the unit again. I turned off the power and as quickly as I was able to, checked the defrost thermostat and heater in ohms. The defrost thermostat read 2.5 and the heater read 24.5. This was while the temp in the freezer was approximately 44-50. I also notice a few small slivers of ice in the drain pan. Any advice and thoughts on how to proceed or the issue would be greatly appreciated.
