hazard
- EI23BC56IS2
- Electrolux
- More than 10 years
July 2021 I was very successful using this site to replace the fan when the 'fridge compart was getting to warm. See the link at the end of this message. I mention this as I thought it was happening again.
Day 0, In the morning I notice when I get a swig of water from the jug I store in the 'fridge while cool, its not cold. The temperature reading on the external display says the freezer is 0, and the fridge is 53 degrees normally its 37, hmmmm.
Other observation.
IN the past when the display gets screwy, its happened a few times, the disconnect for 10 minutes or so seems to do the trick.
Freezer is working and is set to 0 and I believe thats what it is operating at.
I have perused this site and here is what I think it could be but not in any particular order:
My thread from 2021 when I replaced the fan.
www.applianceblog.com
JH
- I check the fan, I hear it running but I open the freezer and depress the door close trip button and it starts running. SO the fan is fine.
- I had recently put several 4 packs of IPA in the fridge, and had moved stuff around a bit, so I pulled some stuff out and made sure it was not overcrowded, because thats the last thing that changed. No improvement.
- Next I disconnected power for 10 minutes. When I re-applied power, acked the power loss, displays the what the temp is set for (37 degrees) then jump up to "HI" and watched the temperature over the course of the next hour, it was dropping and by the time i left from "HI" to 53, 52, 50....45..." SO I assume it was fixed.
- I called my GF who is working from my house to check on it and she sent me the picture of the external display which showed it was back at 53.... I ran her through how to disconnect power from the breaker and reset it. Again it starts at HI and drops down over the course of an hour or so, but later in the day its back at 53 and holding, I believe the display will go as high as 55 before it display HI, but not 100% sure.
- I use one of those contactless thermometers I using for cooking, and test the temperature of several items in the fride and it agrees with the display 53-55 degrees. (I have this thermometer somewhat accurate in playing with it to measure temperature of lots of objects indoors and out over the course of the last few years.)
- I reset again from the breaker. Let it set for about 15 minutes. Once I re-connect power and ack the power loss warning, it shows its normal temperature setting (37) then jumps to HI, and is now decreasing to about 51 and its been a couple hours, but granted we opened it a bit to get lunch made.
Other observation.
- Frost preventing the flow of cold air, it has never been an issue in 10+ years, but it could be some kind of defroster thing gone bad.
- The damper in the fridge is wonky, electrical or not opening the whole way.
- SOme kind of sensor, although the display seems to be accurate to the actual temperate of the compartment. Is there another sensor?
- Some kind of control board.
- SOmething else?
EI23BC56IS2 Electrolux French Door Refrigerator/Freezer. Fridge Compartment is warm. Freezer Seems OK
Last night I noticed that my control panel had a funny code looks like SY Lr (see attachment) (as a note I think my LED displays has some issues). It also has a warm indicator light on. Because of some access constraints I turned the breaker of for about 30 minutes after turning it back on it...
JH
