Electrolux oven broiler element goes on after oven is at selected temperature
H in OH
NE OH
EW30IS65JSC
Electrolux
The broiler element goes on and stays on after the oven reaches the selected temperature.
The control panel does not show any temperature higher than its target setting. I can see the temperature keeps going up using an oven thermometer on a rack.
The control panel does not display that the broiler is on, although the broiler element is glowing red.
The oven temperature probe tests with a 1079 Ohm resistance at room temperature.
The old oven relay board had a burned out resistor (as in black, charred and exploded). I replaced it with a new relay board.
I replaced the control panel with a spare on hand.
The problem persists that the broiler element comes on and stays on even when the controller does not appear to think it is on. Am I to just assume that the new oven relay board has a defective broiler relay, or is there something else in this oven that can be leading to this failure?
--H
Yes, if the oven sensor is good, then the control board is the part it can be to cause this problem.
Look here:
And here:
Here's the relay board for your model that controls the broil:
316443916 Board
