Electrolux Refrigerator EI27BS26JS3 Fridge section going too cold
corner27
EI27BS26JS3
Electrolux
I picked up a second hand fridge for cheap because the fridge was going below freezing from time to time. That's all the info I got on it. I have it plugged in and sure enough even though it's set to 4c, it was at -1c this morning.
I've read a few things about the damper and the thermistor. I'm assuming the damper should be closed. What is the diagnostic procedure to test the thermistor?
Any other troubleshooting steps I can do?
Its best to manually ohm test the Fresh Food Temperature sensor(thermistor) with a multimeter.
Place the Fresh Food Temperature sensor is a small glass and fill it with crushed ice. Add enough water to cover the Fresh Food Temperature sensor. Then wait at least 5 minutes. This should bring the temperature of the Fresh Food Temperature sensor very close to 32*F-33*F. At 33*F the Fresh Food Temperature sensor should measure 31,658 ohms. At 32*F the Fresh Food Temperature sensor should measure 32,566 ohms (+ or - 2%). Your Fresh Food Temperature sensor should be between 31.6K and 32.5K ohms.
Here's the Fresh Food Temperature sensor for your model you can order, if yours ohm tests bad:
Thermistor 240597203
Here's the video to access/replace both of them:
Correct.
If the thermistor ohm tests good, then its possibly the damper.
Here's the air-damper for your model:
Damper Control Assembly 241518501
Here's the video to access/replace it: Frigidaire Refrigerator Damper Control Assembly Video
