max57
- EI28BS56IS0
- Electrolux
- 6-10 years
I have Electrolux fridge EI28BS56IS0 not cooling and I notice a little ice at the entry point to the EEV .
I ran test 49c and I can feel the motor in the EEV working and I it displays on-open and off-closed.
I then run test 62c and do feel the EVV opens and the display flashes 52F and then I see F on the display, I assume it failed
what exactly this fail mean?
The compressor and invertor are fine as I can feel the compressor running and it warm but not hot-hot.
the fridge is in my garage and it is freezing in there , 32F or so.
The inverter working since the compressor would not run at all. the inverter get 120VAC and 7VDC from the main board.
Corrected model number
