Electrolux wall double oven bake does not work broiler does
james2
spokane
GLEB30T8CSA
Electrolux
Bake does not work in either the top or bottom oven. Broil, however, works in both.
I have pressed reset on the thermal switch (fuse) and it did not fix it. Doesn't make sense both bake elements would go bad at the same time. Sounds like others have found the relays in the control board are bad. Anything you can recommend to do before I order a $250 part.
james2
spokane
More information: Each of the burners go to two different relay boards. Since they are both not working, I am assuming it is not a relay, but the "clock" control board. I can not find any burn marks on the relay boards on either of the wires for the burners. So part # 318010501. Do you concur?
Thanks again,
Yes, I would agree. I've not run into this problem before on any of my service calls as of yet or I would tell you definitely what part is bad.
Here's the clock oven control board for your model you can order here: Frigidaire 318010501 Clock/timer - AppliancePartsPros.com
But I'd first make sure that thermal fuse is good with a multimeter, even though you pushed it, it can still ohm out bad.
Thermoprotector 318004900 Order now for same day shipping. 365 day return policy. RepairClinic.com
[video=youtube;fUIQ0u01SyY]http://www.youtube.com/watch?v=fUIQ0u01SyY&feature=player_embedded[/video]
Remember only on our site can you shop with confidence as all parts ordered through our site come with a 365 day full refund even if it was installed and didn't fix it.
james2
spokane
Thanks so much Jake. I'm not going to be able to work on it more until the weekend, but I will update when I do.
Ok James, thats fine, keep us posted.
