DadFixesAll
- EIFLW55HIW0
- Electrolux
- More than 10 years
Good evening, Everyone.
Not many things around the house I can't fix, former Marine, 6097 mos. F18 fighter jet structural mech, I've pride myself on being able to fix just about anything in and around the house including my cars....
Have I met my match in this washer, we have as the title states an Electrolux model EIFLW55HIW0 washing machine, couple days ago it started making a loud groaning sound on the rinse/spin/drain, basically tail end of the wash cycle, after some ear to walls detective work, found the noise was coming from the front. ran a fast wash and notice it was draining slow second go round got a too long to drain message and E21 error code, pulled it apart tested the drain pump, no good, ordered and replaced it, ran through the diagnostic sequence, every component works except the drain, got a code for the pressure sensor, ordered and changed it. No codes active now, machine still won't drain, I pulled all the drain parts out during pump install, boot from the drum, drain tube to house, drain basket inside main tube from drum, inspected and cleaned everything, very little debris, nothing that would cause a blockage.
What am I missing? could it be the control board? even though every other option and button works flawlessly, right now I am under $300, new pump, new pressure sensor, door boot had a small tear so I replaced that. not sure how far down this rabbit hole I want to go, for now I am still under the halfway mark for a new washer. is there a master reset sequence that puts this thing back to factory reset mode?
any help, guidance, opinions, suggestions are welcomed.
