ELFW7637AT Electrolux washer Drain Filter?
drlarry
Atlanta
ELFW7637AT
Electrolux
Less than 1 year
Does this Electrolux washer have a drain pump filter?
Background: I recently purchased this Electrolux washer to replace a 10 yr old Kenmore washer. This new Electrolux machine is operating just fine, but I want to maintain it properly. My previous Kenmore washer had a drain pump filter located at the front-lower-left of the unit that I could periodically remove and clean (remove dog hair, etc.) as needed, to protect the drain pump. Does this Electrolux machine have a drain pump filter that I can access? Or are there any other related maintenance tips I should be aware of to protect the drain pump?
Thanks in advance for any advice.
Yes but it looks to be internal to the machine.
LINK > ELFW7637AT Washing Machine Filter
I think a pump problem should be a fairly minor concern. To try to prevent harm to it i can only suggest checking all pockets before washing. If the filter gets clogged the washer will need to be serviced.
