Emerson MW8999SB Microwave Arcing
layers1
San Antonio, Texas
MW8999SB
Less than 1 year
Microwave is arcing & humming when turned on.
There is no metal inside the unit.
The metalized removable card inside has burn marks on it
Please help
Thank you,
Larry
Try cleaning the burned spots the best you can and cover the spot with a piece of masking tape. If it continues to hum that's usually a sign the mag tube is is weak and needs to be replaced. If you remove the cover you should be able to tell if it's the tube or the transformer.
