Estate Electric Dryer wont start
smieri6
Opelousas
Hello we repair Appliances. And this is the second Estate Electric Dryer we've had with this problem. We've have done all of the trouble shooting and it wont start. What could be the problem. Model # EED4400WQ0
Totally dead with no sounds?
What "tests" did you do?
Q - My dryer is dead, what could do that ?
A- Common problems...blown house fuse/tripped breaker ( electric dryers need 2 )...loose white/neutral wire...broken belt ( on some models only )...door switch/door switch bracket...*thermal fuse open ( venting needs attention )...broken or burnt wire...timer...motor...burnt power cord/plug...start switch ( especially the ones with a built in relay switch )
* If you find a blown thermal fuse, always clean, change, adjust the venting system and vent hood first.
