EW23BC71IS0 Electrolux Error code
Scapin
Los Angeles
EW23BC71IS0
Electrolux
Any one ever see a code on the front panel 5h h3?
I couldn't find the one you wrote down.
I found:
Code SY EF
Code SY CE or SY CF
Code OP SH
Any of these right?
I saw high temp on the display, are the temps good?...not good?
Any thing runs? Fans, compressor?
Have you tried unplugging the refrigerator for 30-60 minutes to see if the control will reset?
I have no sound so I could not listen to this, does this help at all...
[video=youtube_share;99U76rUPiHA]https://youtu.be/99U76rUPiHA[/video]
Scapin
Los Angeles
After going through the diagnostics, It is cooling. The problem is the defrost not happening. Is there a video on what to change out for that for this model?
We normally don't need to worry about fault codes to check a defrost issue.
Defrost-Heater-Assembly-5303918410--01229248.jpg Defrost heater
[video=youtube_share;311BiD76iYg]https://youtu.be/311BiD76iYg[/video]
We check the above first, if ok we replace the defrost control.
Main-Control-Board-5303918507-01210661.jpg Main power board
Scapin
Los Angeles
Replaced the defrost heater, but it only defrost manually. Is it the thermostat or the control board.
Did it check as being bad?
Don't believe your refrigerator has a defrost thermostat if that is what you meant.
Scapin
Los Angeles
The defrost heater must have been bad because it wouldn't defrost manually. Since I replaced it, the manual defrost works but not the automatic.
