Ewave Microwave Oven
bparke20
Southfield, Michigan
I have a Ewave microwave oven, model NO: KOT-153UB. I went to use it and it popped the Circuit-Breaker. I reset the Circuit-Breaker, and it's providing power to the wall-outlet; However, the microwave is still inop. My question is.....is there a simple repair for this microwave such as an internal fuse replacement? Or is this microwave toast which means I'll have to replace it with another. (bparke20)
Unknown until you or someone diagnoses the problem(s).
There is a fuse inside the microwave but fuses and breakes don't let go or trip off normally without a reason.
Shorted high voltage capacitor, bad door switch(s), burnt wire are common trouble makers for taking out the house breaker and/or the fuse inside the microwave.
