- EWED65HIW0
I am getting an E64 error code on my dryer. This indicates a heating element issue.
I tested the Element, High Limit Thermostat and Fuse... they all tested OK but each has now been replaced. Still receive the error message. New parts test with continuity as expected.
I tested the inlet thermistor and was not getting resistance, this was replaced but still no heat. New piece resistance tests with 57k ohms
I have checked the voltage at the outlet and to the terminal. 240 as expected. I have flipped the breaker just in case.
I have tried to check the control board but that is a little tougher. When not running, the heater relays test as open, when running in a heat cycle they test as closed. From what I can tell this is to be expected for proper functioning. That is as far as I have tested.
There is an outlet thermistor - I did check that last night and was not getting good results... seemed weird that both would be out but I would not get a thermistor code so I figured I was testing it wrong.
There is a fuse on the exhaust as well (forget what it is called) that tested with continuity.
I am down to thinking it could be the control board, outlet thermistor or wiring. Any thoughts on something I may be missing or good ways to test from here?
*I have also checked for things like lint blockages, fan blades and such... all seem OK.
