FIXED EWFLS70JSS0 Electrolux washer code 35
Ice monkey
SC
EWFLS70JSS0
Electrolux
During a wash cycle, the washer will sometimes ‘ding’, then show Code 35 Call Service, and keep filling with water. Even after the wash cycle is cancelled the water will keep flowing. We have to shut the water off, then do a rinse cycle with the water off to get it to drain.
Previously, we were getting a Too Much Soap message, and it would at times do the 35 code. I moved the hose out from the drain some, and that seems to have fixed the other issue, but we still get the Code 35. I‘ve fixed components on this washer before, but not sure where to start or if I should just call for repair.
--->3. Remove power from washer. Does the water stop coming in?
No. Replace the water valve assembly.
Here's the water inlet valve for your model you can order if the water keeps coming in when the machine is unplugged from the wall outlet:
Water Inlet Valve 134637810
Ice monkey
SC
Yes the water does keep going with power removed. We have to use the water shutoff.
Would that cause the Code 35 as well?
Thanks!!
Yes, that would cause the error code 35 as well.
Order and replace that water inlet valve and you will be back in business.:)
Ok, sounds good.
Yes, keep us posted.
Ice monkey
SC
The water inlet valve arrived today. I replaced it and we ran a load. So far so good, no code and it ran normally. That seems to have done it. I’ll update if that changes.
Thanks again!
Excellent @Ice monkey glad to hear the new water inlet valve fixed it.(y)
