FIXED FAFW3001LW3 Frigidaire Washer - Replacing door boot
Brianswensen
California
FAFW3001LW3
Frigidaire
I am changing a door boot on a stacked Frigidaire washer (part number 137566001). Does anyone have any tips on how to get the spring on that holds the boot to the tub? I always have the hardest time with the spring on the Frigidaire/Electrolux washers. All the online videos make it looks so easy.
I will probably attempt to change the door boot without taking the front panel off since the dryer is stacked on top and is in a closet. Is there a boot clamp that tightens with a screw (i.e. the kind samsung uses) that would possibly fit this size gasket. Thanks for your help!
Brian
Hi Brian,
Yes, the Frigidaire boot seals are the hardest to replace, Its going to be a nightmare to try to replace it without removing the front panel unless you have extremely small hands and arms. LOL
There isn't any tips I can give you on doing these, sorry.
Here's the video:
Brianswensen
California
So it turns out the LG inner door boot springs will work on these. I was able to do it from the front pretty quickly without taking it apart. It wasn't too difficult getting the new gasket on the tub with a lot of soap. It kind of took a while to find the spot on the gasket that needed to be pressed against to get it all the way on the tub.
The LG inner ring was a little too big, so I took the spring off, bent the end of the ring about an inch and put the spring back on the ring. Once that was the right size, I installed the ring the same as with an LG washer using this tool 383EER4004A.
Assuming it holds, these will hopefully not be everyone's worst nightmare anymore. I feel like Frigidaire couldn't have made a worse design with those inner door springs they use.
Good job Brian, thanks for letting us know. (y)
