FAFW3001LW3, stackable washer, random beeping,
stevep279
Ct
FAFW3001LW3
Frigidaire
Hi all,
Last night my washer began to randomly beep and the digital display would turn on and off. I tried washing a small load and it seemed to function properly but the beeping continued after the washer was done. I turned the breaker off last night. Turned it back on this am and the beeping continues. Doesn't matter if the door is open or closed. I've got the code E41 from the machine. However last December I replaced the control board and the door latch switch. Also repaired a broken wire at the same time. Any help would be greatly appreciated.
Steve
stevep279
Ct
Hi Jake.
Thanks for the reply. I too was thinking it was the control board. I just replaced it though in Dec. of 2018. I'd have to go back and look where I purchased not from but is there usually a warrantee for this part?
Ok Steve,
When you order parts from AppliancePartsPros and RepairClinic, you have a 365 day full warranty on ALL parts.
Hopefully you got it from one of those two.:)
If so, just contact them and they will send you another new one free of charge.:)
Ok, thanks for the update!
