Fan Blade broken on rooftop range hood exhaust model GE 5KSP29HG2477S
Maxime
Toronto
5KSP29HG2477S
Hello,
My range hood exhaust fan is located on my roof. One of the blade just came off and fall. Motor is quite old and I am looking at what model should I look for fan blades replacement that can fit in the motor GE 5KSP29HG2477S. Motor works fine. I attached a picture of it for information. Thanks for your help !
Maxime
What is needed is the brand name of the hood unit (not the fan motor) and the model number of the hood unit (not the fan motor). That motor could be used on numerous hoods, each utilizing different fan blades.
Failing that, try taking the fan blade (not the motor) to a local HVAC supplier to see if they can match up a replacement fan that is suitable.
JMO
