Fan not shutting off
jimg3
United States
NN-SN968B
Panasonic
Woke up to fan running running on microwave. When opening the door - fan stops & light turns on. Pressing start (door closed of course) turns on light, carousel turns, food heats. Just the fan won't stop. Tested micro-switches with a multimeter - all seem to be operating correctly.
Disconnected the thermostat - fan (and everything else) turns off. Any suggestions welcome.
Still sounds like a door switch, door key, door switch mechanism issue.
Thanks for the chart Jeff. Not quite sure how that maps to my actual switches.
And here are the multimeter results.
Not sure on where the HV Transformer is, so I didn't perform that test.
2 should open and 1 close when the door is opened, 2 should close and 1 open when the door is closed. If they check ok, leave a bad board as prime suspect....not overly common as the switches/switch mechanism!
