FIXED FAQE7011KR0 Frigidaire electric dryer will not shut off with the door closed
savatage70
Ohio
FAQE7011KR0
Frigidaire
dryer runs and dries great but will not shut off at the end of cycle. door has to be left open. does not continue to heat at end of cycle but drum keeps turning.
If it also will start running before the start button is even pressed, that could be caused by a shorted 'push to start' switch or in the case of an electronic control model, a shorted motor relay. On your model both those components appear to be part of the electronic control itself.
If either of those is the cause in your case, the electronic control likely needs to be replaced. :(
LINK > Frigidaire FAQE7011KR0 Electronic control # 137070840NH
savatage70
Ohio
Received replacement part yesterday and installed this morning. Took every bit of about 10 minutes, very easy install. Working great, Thank you very much Dan O.(y):)
