FASE7073LW0 Frigidaire dryer noise on anti static cycle
GR8TSCT99
Denver
FASE7073LW0
Frigidaire
I have a Frigidaire dryer, as and it makes a loud noise when it is on the anti static cycle. It works great all the way through the drying cycle. I can't find any help online,
Had anyone run into this problem? What is it? Thanks for the help.
Without a model number, we're dead in the water. Read it from the tag on the machine. Click here: Appliance Parts follow the link “How to find a model number”
GR8TSCT99
Denver
Model number
It is a Frigidaire Affinity Dryer with the model number: FASE7073LW0. My apologies I forgot to type it in. Thanks for getting back to me.
GR8TSCT99 said:
...and it makes a loud noise when it is on the anti static cycle.
OK, that's not very much to go on. So you're saying it makes a "loud noise" only on the anti static cycle. That means we can eliminate the motor, blower, drum rollers, idler pulley, glides and the drum. They all work the same way in any cycle. That leaves the gas valve assembly and the console electronics. Can you tell where the noise is coming from? Here's the hard part, can you describe the noise? It might be faster if you made a youtube video and post the link here.
GR8TSCT99
Denver
So I tried to do it again, with my phone video taping it, and it didn't make the sound this time. It was a loud buzzing noise, to loud to be normal. If it does it again, I will upload a video of it. Thanks for trying to help me.
So it's an intermittent noise only on the anti-static cycle? Can you tell where it's coming from?
GR8TSCT99
Denver
It made the noise only once and hasn't made it since. It was so loud it sounded like it was impossible to know where it was coming from, but I did hit cancel before I investigated it even further. The closest sound I can think of is a fire alarm buzzer. I haven't gotten it to do it again. In 3 loads.
kamado
corpus christi texas
Mine makes the exact same noise. its a very loud grinding noise that only happens on the anti static cycle. it use to never do it. Is your water hooked up to the dryer for the steam function. I have a feeling it has something to do with that. At our old house we had it hooked up. At the new house the way the laundry room is there is no water line to the dryer. A few months after we moved in it started making this loud its not really a grinding sound, It almost sounds like the most annoying noise in the world from the movie dumb and dumber. Its a loud EHHHHHHHHHHHRRRRGGGGGGGG noise. Its hard to pin point exactly where the noise is coming from bit you can here it across the house - I dont have the model number off hand its a 7 year old Frigidaire affinity dryer
