- FASE7074LW0
- Frigidaire
- More than 10 years
Frigidaire Affinity model #FASE7074LW0
My dryer stops within 3-4 minutes on sensor mode, about 1 minute on time dry, and 6-10 seconds on air dry. Below are the steps I took and observed. I have not done anything to the thermal limitor, thermostat, nor thermal fuse, but doubt that is the cause. Please help!
- Moisture sensor is not the cause - dryer stops on time dry, air dry, and sensor mode
- Motor not overheat- I cleaned the motor. Dryer turns on right away when pressing Start after it shuts off.
- Cleaned lint and vent
- Not door latch - tightly closed
- Dryer belt not an issue - the drum turns fine
- Control board replaced about 10 months ago
