FASG7021NW2 Frigidaire Dryer again with the thermal limit, fifth time
hrt jr
mn
FASG7021NW2
Frigidaire
FASG7021NW2, serial 4D31201041, DR code- this will be the fifth time in seven years- so is there a higher temperature option? I dis assembled the lint screen area and got that area spiffy clean, duct clear, outside 4 flapper vinyl is completely free/ open. Honestly I'm fed up enough to replace it so another question - do new dryers run the same way? I have it on a 15 inch pedestal, will a new fridgidaire fit on the old pedestal? Do other manufacturers dryers fit on this pedestal? thanks
How much lint was there? (It could be a clue.)
Exactly how long is the venting all the way from the dryer to the outdoors?
How many elbows?
What material is the venting made from?
LINK > How long can my dryer vent be?
hrt jr
mn
Two elbows, about 11 feet of rigid 4 inch alum-
I vacuumed out the dis assembled the lint filter area, took the straight apart and made sure was clear last year when this happened last time- as well as more than monthly clear the flapper vinyl vent (I own a handyman repair business)
The venting sounds good.
- Check the seals on the drum. If they're leaking, proper air flow through the dryer will not occur.
LINK > FASG7021NW2 Dryer Drum Seal (2 used)
- Also check the seal between the front panel and the blower housing. Again, leaking will affect air flow through the dryer and affect the heat control components.
LINK > Air Duct Seal
- Check the the drum support rollers. They could be worn and preventing the drum from sealing properly against the housings.
LINK > FASG7021NW2 Drum Support Rollers (2 used)
- As a very unlikely possibility, make sure the fan is attached firmly onto the motor shaft and not slipping. Also that it's clean.
I'm not certain if a different manufacturer's dryer would. I don't know the pedestal's requirements. Check its installation instructions.
