FIXED FEB27S5DSG Frigidaire Wall Oven F30 Error
Brianswensen
California
FEB27S5DSG
Frigidaire
On a Frigidaire wall oven getting a F30 error, should I be looking for something other than the temperature probe or control board? I'm looking at the wire diagram and am guessing that it could also be a problem with the cooling fan or cooling fan thermostat, but can't tell which thermostat goes to the fan.
The oven preheats fine then the bake element cycles normally on and off for about 20 minutes. After that amount of time the F30 pops up. Thanks!
Did you ohm test the oven sensor yet?
(F30) Open RTD sensor probe/ wiring problem. Note: EOC may initially display an "F1", thinking a runaway condition exists.
1. Press CLEAR key.
2. Check wiring in probe circuit for possible open condition.
Check RTD resistance at room temperature. If resistance is not between 1050 to 1100 ohms at room temperature, replace the RTD sensor probe.
3. Let the oven cool down and restart the function.
Here's the oven temperature sensor probe for your model:
Temperature Sensor 316217002
Brianswensen
California
I think that is working ok. I did an ohm test and it was fine. I had an extra sensor with me so I put it in just in case but didn't help with the F30 error. I am going to bring the cooling fan, fan thermostat and control board out with me when I go back to fix it. Is there anything else I am missing? Thanks!
Nope, you should be fine with those parts.:)
Excellent Brian, glad to hear the new control board fixed it.(y)
Here's the control board for your model in case others need it too:
316418525 Clock/timer
