FER300SB/XAA Samsung Electric Oven Inaccurate Oven Temperature Reading
firefighterdc
Texas
FER300SB
Samsung
Example: Turn on oven, set to 350 degrees. Oven digital screen gets to 350 and beeps, BUT temp is 275. About 3 minutes later temp gets up to 350. Sometimes it won't get to set temp, and if you bump it up, it goes way over temp. Circuit board new in June of 2016 because LCD screen going out. I took temp. sensor out and took ohm reading 1096 at room temp (in range according to Samsung tech pamphlet taped to stove back). Ohm reading on heat element was 16.7 (I don't know if this is within spec). Any suggestions would be great. Even if temp sensor is within ohm specs, can it still be defective? Thanks
Forgot to mention that I checked for error codes....screen showed "no epp"???? Don't know what that stands for.
Possibly yes, its rare but can happen. Normal ohms at room temperature is 1050 to 1100 ohms. So your in range at room temp. but yes as the temp. rises it can be off a bit.
Only two parts control the oven temperature, the Clock Oven Control Board, which you mentioned was already replaced, and the Oven Sensor.
Here's the Oven Sensor for your model you can order:
Temperature Sensor DG32-00002B
Here's the Clock Oven Control Board for your model:
Main Control Board DE92-03045B
I have no clue what NO EPP stands for, sorry.
Wild may know, I will ask him, hes more versed on Samsung than I am.:)
wildimaginations
Danville, California
Not sure about NO EPP but it may be a special code used by Samsung tech support for informational purposes.
Check your oven calibration by referring to page 27 of the Owner's Manual and using a digital thermometer to test.
