Emuld123
- FEX831CS0
- Frigidaire
- 6-10 years
The washer fills with water but will not agitate, there is no noise from motor after it fills. if I advance it manually it will drain and spin but not agitate, I checked the pressure switch and it does click . I also blew out the hose to the pressure switch and it did not have any blockage . I replaced the timer ( which looked used when I got it) but that did not change anything. is there anything else it could be ? is there a way to test the timer to see if that is the problem ? Thanks for your help
