FIXED FEZ831AS1 Frigidaire Over under not draining
Hi Mike,
I'd first check for an obstruction in the drain pump itself. You may have something in the drain pump, that would cause a not draining issue.
The drain pump is located inside the bottom of your washer, you just remove the front panel of your washer and get a flashlight or droplight to see under there.
Lots of times I see these get clogged with stuff and not drain properly, just remove the hoses that connect to it and check to see if anything is inside it.
Get a bunch of old towels to soak up water that will come out.
Drain Pump 137221600
There is a video in the part link that shows you how to access it and remove it.
slackkeymike
Huntsville, Alabama
crap, figured it out. bent nail stuck in pump. I swear, im gonna inspect all clothes before washed lol!! Thanks Jake! (installed a new pump, no sense in taking a chance with a damaged one). Sending $10 for ur support
Excellent Mike, glad to hear that's all it was. (y)
Thanks for the update and tip!
