FFCD2413UB4A FRIGIDAIRE DISHWISHER TECH SHEET
budjack
louisville Ky
FFCD2413UB4A
Frigidaire
Less than 1 year
TECH SHEET is it in the front panel. new unit.
Corrected model number
So what's the problem?
Sorry Bud, I didn't see a ? mark after what you said. I read that wrong, my bad.
If its not behind the front lower access panel, then its likely in the control console at the top of your dishwasher door.
Nope, not on that one, sorry.
Good catch bigbuck!
FFCD2412UB4A might be FFCD2413UB4A
budjack
louisville Ky
I know this is not the right place
I have had warrant work done twice on this unit the water valve and fill hose one the third time tech said he saw the unit siphoning.
On the first pre wash the unit does not fill with enough water most of the time I open the door and add water with the spray hose it works fine the rest of the cycles. Why would it siphon just on the pre wash?
I have used the drain systems for 30 years know problem. I have a loop on the drain line above the dishwasher. It drain to the drain in the basement. I do not see it siphoning. What can I fix he will not come back says it is my drain systems.
Check valve, control, or pump.
That I don't know, sorry, unless you have a air gap in the drain system as well and that is clogged.
Or where it drains to in the basement has a semi-clog in it, causing a slower than normal drain out to occur.
