FFGF3017LBE Frigidaire Range - oven recently stopped heating up
Shankly85
New York
FFGF3017LBE
Frigidaire
Hello,
My gas oven recently stopped heating up, I assumed it was the oven ignitor, as this would be the third time replacing it in the short time I’ve owned the oven. I removed the oven ignitor and it didn’t pass a continuity test with a multimeter, ordered a replacement.
Installed replacement and to my dismay, it didn’t work, not even a glow from the ignitor. Unfortunately I don’t have a ladder diagram or schematic for my model, is the supply voltage from the circuit board to the molex on the ignitor 120 VAC when oven is set to bake?
Any pointers or opinions would be greatly appreciated, I will add that the gas stove top works fine, got power to display as well, I removed the circuit board (will attach photos) there are definitely some dingy spots on the pcb, but I can’t spot any specific blown component on it. Thank you.
When its ON BAKE 350 you should be getting 120 Volts AC to the oven BAKE igniter so it can start glowing. If no 120 volts to the oven BAKE igniter, then your clock oven control board is the culprit.
Here's the clock oven control board for your model:
Shankly85
New York
I had a hunch, you’re the man Jake! I just ordered the part ( I appreciate the link) I’ll let you know how it goes, thanks for the help!! 👍
Sounds good, yes keep us posted.
I had this same thing happen a couple years ago in Blythe, CA. on this same model and the new clock oven control board fixed it too.:)
