FIXED FFHD2250TS3 Frigidaire Refrigerator Ice tray not filling after moving
Hatrackr
Wisconsin
FFHD2250TS3
Frigidaire
I moved my Frigidaire French door refrigerator ( had to lay on its side) and prior to moving it was making ice fine but now it will not fill with water. The water dispenser works fine, it is plumbed direct to a supply line so it has great pressure. I’ve tried a new water inlet valve and a new ice maker tray and nothing will trigger it to fill. I also swapped the water dispenser and ice make plug on the inlet valve and can fill the tray by depressing the water dispenser so it’s not a plugged or frozen line. Any ideas what else could be wrong?
Hi, Here's the tech. data sheet for your model: https://ecommcdnprod.azureedge.net/...roduct_support/DGH/DGHF2360PFBA/A06589001.pdf
Do TEST 55C that I posted the chart in post #2 here:
Your model uses that exact same ice maker in post #2.
Let us know what happens.
Hatrackr
Wisconsin
I just found the info about running the diagnostics on the fridge. I ran all the tests for the ice maker and it ran everything and filled with water. Hopefully that takes care of it! Thanks for the info!
Excellent.(y)
So everything is back to normal now?
Hatrackr
Wisconsin
Not exactly. The water in the tray never froze so I tore it all apart tonight and defrosted everything with a hairdryer. When disassembled I notice the wire for the fan was disconnected. I’m guessing the harness came apart during the move. I got everything dry and put back together and ran the diagnostic to fill the ice tray. 1 hour later the water has frozen so I’ll see if it continues to cycle and make ice overnight
Hatrackr
Wisconsin
Woke up to a full bin of ice! I’m guessing the fan not working was keeping the tray from cooling enough to cycle even though it was zero in the ice maker according to my thermostat. Hopefully it doesn’t freeze up again and we are good to go
Bingo! Good find.(y)
Yes, you should be good to go now.:)
