FFHS2611PFBA Frigidaire Refrigerator - Not Dispensing Water
G
Guest
Guest
FFHS2611PFBA
Frigidaire
HI. I have no water being dispensed. I replaced the microchip that in the control. I just tried a new water valve inlet. The water valve does work. I can hear it. The microchip works bc I have ohms. The only thing I have replaced is the water base(where the filter plugs into. When I put the filter out(which is new) water splashes all over the place inside the fridge. So what gives???? I am not sure its making ice. And yes the water line is turned on.
Also. Can someone take a pic of there water lines at the inlet valve. I just wanna make sure I have them back where they should be. I am 99.9% sure I have them right. I know. I should have taken a pic. Thanks.
Here's the water filter housing for your model:
Water Filter Housing 242009602
Make sure the water lines are pushed in all the way into the blue lock rings on your water filter housing, or it will leak.
Here's the water filter for your model:
Water Filter WF3CB
