FFHS2611PFEA Frigidaire (French Door) Freezer not freezing properly, Fridge works
Mfarar
Bella Vista, AR
FFHS2611PFEA
Frigidaire
Freezer not working properly, fridge works fine. Meat is frozen but the ice cream melted. Compressor runs, compressor fans is working, coils have been cleaned. Freezer door seals properly, frost pattern doesn't suggest that the defrost heater is malfunctioning. I'm not sure what to do at this point.
Mfarar
Bella Vista, AR
Side note: I hooked everything back up with the panels put back in place and I'm leaving it running for 24 hours and I'll take a photo of the frost pattern at that point
Yes please take a photo of your evaporator coil so we can see the frost pattern, sounds like possibly a sealed system problem.
Yuppers, its a sealed system problem.
The sealed system consists of the compressor, condenser, evaporator, heat exchanger, filter/drier and refrigerant. Common problems with a sealed system are bad compressors, refrigerant leaks, and system restrictions.
Check your owners manual warranty, some models have up to a 5 yr. parts and labor warranty on the sealed system.
Glad to help Mfarar.
