FFID2426TD2A won’t start
Gposcar
NY
FFID2426TD2A
Frigidaire
Frigidaire Dishwasher won’t start.
I recently replaced the latch as it was broken. This is the part number that I used
Dishwasher Door Latch For Frigidaire Part # 5304516818
The dishwasher will not start, I flip the breaker on, all the lights turn on and then the start LED flashes 14times. After this non of the buttons are responsive and nothing works. The door still won’t latch or budge.
Please assist thank you.
It sounds like you got a defective door latch assembly, I've replaced many of these for my customers and it always fixes it, you can ohm test the door latch switch to verify that. Disconnect power to the dishwasher first before ohm testing.
Here's the door latch switch assembly for your model: Latch 5304525218
Without the door latch working properly, the rest of the machine will never work at all.
Gposcar
NY
I recently replaced the door latch assembly, could it be anything else?
Yes, I know that, but it could have come damaged or defective, did you ohm test it?
Two terminal ohm test:
Three terminal ohm test:
